Home Forums TaG Rotax Max Throttle Cable Fixation Kit?
This topic contains 2 replies, has 2 voices, and was last updated by  Chris Fraser 4 years ago.
  • #21977
    Chris Fraser
    Hello,
    I am just setting up a new-to-me rotax and I don’t have anything to go in between the metal elbow and the throttle cable.  However, the throttle cable has a metal tip on it already so it will be metal to metal.
    I don’t remember having anything on my old one other than a little rubber boot to cover the connection, however when looking at the diagram there are four parts labeled as a “Throttle Cable Fixation kit.”  What is the purpose of these, and are they needed?
    In this link they are parts #8,9,10,11: http://www.accelerationkarting.com/vhsb34.aspx
    #21983
    Are they absolutely needed, no.  Parts 9 & 10 are a means to adjust the throttle cable. You might have an adjustment screw similar to part 10 at the chassis tab where the sheath for the throttle cable ends with a nut to prevent it from turning.  The concern would be the tube that is attached to the carb top is threaded on the inside to accept this adjuster and might wear the throttle cable if not in place.
    #21986
    Chris Fraser
    Thanks Tony.  I do have a way to adjust the cable at the other end so I was curious.
    Good point on the threads.  It has the newer style 360 degree elbow and I didn’t notice any threads, but will look again.
    In any event I will get the right parts, but was just curious about this weekend since I won’t be able to get them in time.  Thank again!
