Home Forums Shifter Karts the difference between k9b and k9c cylinder
This topic contains 2 replies, has 3 voices, and was last updated by  Glenn L Riggs 3 years, 7 months ago.
  • #28953
    Birle Daniel
    Hi! I just bought a tmk9c engine and when I looked closer near the spark plug on the cylinder head I saw write k9b. My question now is if it can be k9b cylinder on k9c. These two cylinders are different? How can I figure out?
    #28957
    Steen Carstensen
    Go to Italian Motors website, and look up the homologation papers for the K9B and K9C, it will tell you right there if there is any difference between the two.
    #28963
    Glenn L Riggs
    K9c has a little flat window on the right rear (drivers side) of the cylinder k9b doesn`t  Hope this helps
