Home Forums TaG Rotax Max Target Min/Max RPMs?
This topic contains 2 replies, has 3 voices, and was last updated by  Thor Mauthe 3 years, 1 month ago.
  • #39807
    Matt Clark
    What do you guys try to shoot for with regards to min and max RPMs? Looking at the owners manual, it seems there’s a drastic dropoff around 12k RPM, but I’d imagine momentum plays a factor at that speed. Thoughts?
    #39836
    Eric Alexander
    Matt, keep in mind you should let the stop watch be the final indicator as to gearing.  But a Rotax senior should easily rev to over 13,000 rpm.  A well sorted senior should be capable of revving to close to 14,000.  Although that might not be necessary depending on the track.
    #39868
    Thor Mauthe
    We ran our MiniMax between 12000 and 12500 RPM last year without any issues and producing good power. We had more issues with heat and loss of power then RPM drop-off.
