Home Forums General Karting Discussion Taking a tire off the rim?
This topic contains 11 replies, has 11 voices, and was last updated by  Dave Holstein 2 years, 10 months ago.
Viewing 12 posts - 1 through 12 (of 12 total)
  • #43285
    Bob Spedding
    ok, so I am new to this but one thing I am struggling with is getting the tire off the rim.  I know there are devices for this and someday I may purchase one but just getting into this and cant really afford it right now.  I’ve seen videos where people just push the tire on the rim and I’ve tried that but just can’t get it.  Any other options or is there a better method?  Thanks guys!
    #43287
    Keymaster
    Here is a more affordable tool : http://cometkartsales.com/Tire-Pryr-Kit-for-5-inch-Wheels.html
    Otherwise, it’s all hard labor. Some use screwdrivers, others can just do it by hand.
    #43288
    Ted Hamilton
    Helps if you “fold” the tire into an oval and slide the rim into the wide part.  Also, some rims have a taller inside than outside (or maybe it’s the other way around…)  so install with the smaller diameter, but making sure you’re orienting the tire correctly.  5″ tires can be done by hand.  6″ tires, not so much.
    #43292
    Matt Dixon
    Just call Wes
    94y
    #43302
    Curtis Cooksey
    The Turbo Tire changer is the best tool I have seen, and I have seen and used many over the years. http://www.accelerationkarting.com/tiretools.aspx
    #43405
    Ray Chiappe
    This is how I get the tire off! Add a little Simple Green to reduce drag and pull on the bar.Tire Removal
    #43408
    Ray Chiappe
    A little soapy water would prob. work better!
    #43416
    Kirt Burcroff
    I like this tool. My noodle arms can’t do that manual mounting work.
    http://www.accelerationkarting.com/turbotirechanger.aspx
    #43430
    Gary Smith
    I like to get the tires warm before removing or installing them, makes it much easier. I usually set them in the sun for 30 minutes or so. Use soapy water to lube the beads when you remove the tire. If you have bead locks, make sure you back them off far enough to clear the bead.
    #43524
    Paul Lepper
    I just did 4 rain tires off and put new MG reds on. This was my first time. I bought a Harbor Freight bead breaker and it worked perfectly. It took about 5 minutes to get the first tire off and then I watched every YouTube video again and did the other 3 in less than 5 minutes total. Mounting went even better. Here’s a big hint, brute strength WILL NOT make it happen! Be patient and think it through.
    #43534
    Dave Holstein
    You’ll notice that different rim makes will effect how easy or hard it will be.
    Douglas mags are easier than Douglas spun for instance
