Home Forums Tech Talk sunnen mandrel
This topic contains 7 replies, has 3 voices, and was last updated by  Rodney Ebersole 7 months ago.
  • #83547
    Jim Silverheels
    What number Sunnen mandrel would you recommend to hone a Briggs World Formula engine plz? Not talking a flex hone.  thanks
    #83554
    William Martin
    What’s the bore size? Somewhere I think I have a Sunnen catalogue…years old, but still ok for this I think.
    -bill
    #83583
    Jim Silverheels
    Bill, I think the Y72-2625PF mandrel is the one. Thanks
    #83787
    William Martin
    A mere $401 in my 1997 catalog… ugh. Glad you found it!
    #83791
    Jim Silverheels
    Billy, can you lend me some money to buy it? Must be 700 bucks now, yikes!
    #83811
    William Martin
    You might want to check out the SN & JN series of portable hones, not quite so expensive. Not cheap either, but maybe half the cost. I bought an SN-75 model some 20 years ago, for 100cc cast iron cylinders, it works great. Just need a big 1/2 inch drill to turn it.
    #83825
    Jim Silverheels
    Billy, I have an expensive floor model Sunnen Hone with loads of smaller mandrels but nothing big enough to do Briggs World Formula. I ‘ve found those flex drill driven hones to be less accurate with bore roundness. These floor models get the bore perfect for me. just my take on it
    #83832
    Rodney Ebersole
    The portable hone isn’t a flex hone. It uses the same mandrel seen on the AN600 mandrel which is the mandrel I prefer to use when honing a briggs block or FV cylinder in my Sunnen machine.
