--> Stuck hortsmen 2disc – ekartingnews
Home Forums 2-Cycle Racing Stuck hortsmen 2disc
This topic contains 8 replies, has 4 voices, and was last updated by  Walt Gifford 3 years ago.
  • #44580
    Tom Petalino
    Ok, so I’m trying to remove my clutch from the crank and it seems to be stuck. I got the starter nut off ok but then stripped the threads on my clutch puller trying to get the clutch off. I’m going to spray pb blaster on it for a few days and try again. Should I try to heat the crank or the clutch side some? Or am I asking for trouble?
  • #44625
    Jay Sinon
    I would only use heat as a last resort there is a chance that you could change the tensile strength of the metal or possible warp the clutch. Which clutch puller were you using the Horstman one that pulls with 5 bolts or the aftermarket puller that pulls off of the spring perches  or a regular 2 or 3 jar puller? What exactly stripped? were you using air tools?
    When you do get it off and you get ready to reinstall it, try installing it with no key and some valve grinding compound between the clutch and the crank. Spin the clutch by hand on the crank until both surfaces match then clean the valve grinding compound off and install the key and reinstall the clutch this will mate the two surfaces better and help it seat flush on the crank which should make it stay on and remove better as there will not be a rocking motion between the two pieces that could cause a binding or shearing on the key.
    TaG Sr.
  • #44661
    Tom Petalino
    <p style=”text-align: left;”>The puller was a new comet racing 5 bolt puller. The threads on the puller stripped when pressure was applied. I was not using air tools , just an adjustable wrench. I’m going to tap the puller one size larger , should be fine for my next atempt.</p>
  • #44662
    Greg Wright
    Did you smack the center bolt of the puller with a steel hammer? If not you should.
    Greg Wright
    Rapid Racing Inc.
    Vintage B-Stock Pilot
  • #44686
    Tom Petalino
    I was afraid to hit the crank thinking it would bend or damage it.
  • #44726
    Greg Wright
    You want to smack it squarely and sharply, this is normal operating procedure when pulling something off of a tapered shaft.
    Greg Wright
    Rapid Racing Inc.
  • #45012
    Tom Petalino
    Thanks Greg. I tapped it with a hammer and it popped right off. Learn something new every day.
  • #45040
    Greg Wright
    You’re very welcome. Like I said earlier, that’s the way it’s done.
    Greg Wright
    Rapid Racing Inc.
  • #46204
    Tom, 28 Ft. Lbs. next time.
