Home Forums Shifter Karts Stock Moto carb
This topic contains 4 replies, has 3 voices, and was last updated by  Jimmy McNeil 3 years, 9 months ago.
  • #25782
    John Lafakis
    I’m rebuilding a CR125 for stock moto and I believe it has the Mikuni 36mm carb on it (it says Mikuni and ‘TM’ on the side).
    My question is, should I rebuild and run this carb or get something else?  Is this the only carb I can use in stock moto?  I ask because I have read that these are hard to tune (Don’t know if that’s true though).  I will buy a full jet kit for this carb if it will help with tuning.
    Ty ty for any help
    #25784
    Keith Bridgeman
    Your 36mm carb I would guess is a Keihin PJ?   You want the Keihin PWK or PWM, 38mm
    #25796
    John Lafakis
    Are those legal for stock moto?  Which of them is more preferred?
    #25846
    John Lafakis
    Also I picked up the Swedetech  actuator and kick start plugs; do I remove the rubber oil seals before install them so they will mount flush, or do I install them on top of the rubber oil seals?
    thank you
    #25861
    Jimmy McNeil
    Both PWK and PWM are legal in stock moto. The PWM has a little more top end.
