Home Forums Shifter Karts Stock Honda CR-125
Viewing 5 reply threads
    • #12662
      Michael Rutter
      Hello, I have been very interested in this class and mine (mostly my dad’s) concerns are
      • Price of a used motor?
      • Chassis Recommendation?
      • Rebuild intervals and what are usually replaced?
      • usual prices on rebuilds
      An extra would be if anybody has a used motor their willing to part with?
    • #12818
      Michael Rutter
      <div class=”d4p-bbp-quote-title”>James McMahon wrote:</div>
      New kit (you assemble and prepare) $2800 for the 99kit, add another $400ish of you want ’01.<br>
      Brand spanking new and assembled $3800-$5500 (and situations vary
      How complicated is it to assemble? Do you think a fairly mechanically oriented 14 year old could assemble a kit?
      <hr>
      <div class=”bbp-reply-signature”>Be a part of something awesome for kart racing: https://www.facebook.com/kartpulse</div>
    • #12832
      James McMahon
      Hard to say. You will be assembling from absolute scratch, cases, gears, clutch, crank, etc. etc. The kit is a box of over 300 parts. I’m trying to find it online…. but not having any luck.
    • #12833
      James McMahon
      I sit corrected, the kit is in fact $2300, at least from Extreme.
      That said you would need to purchase your carb, exhaust, silencer, motor mount, drive gear and other odds and ends to get it ready to bolt on and run. By the time you’ve bought all that I would guess you would be at $3000 easy enough.
      CR125 Kit
    • #12836
      Matt Dixon
      Just call Swedetech pick up one of their SuperNats rentals for the best price around and have a quality bullet. Drop a top end in it before every race and have them do the bottom end every winter. Can’t go wrong…
      94y
    • #13279
      StockMoto Joel
      I have a spare Stock Moto CR125 6 spd, 99 cylinder (believe cylinder is new)… does not include carb, electrics extra.  $1200 (PM or email me)
    • #12799
      James McMahon
      Hi Michael and welcome…..
      Used cost on a Stock Moto engine package seems to be around, $2800 however they seem to have dropped a little of late. Here’s what I posted in another thread…
      Used about $2500 with a ’99 cylinder, probably $2800-$3500 (or more) with an ’01.
      Brand spanking new and assembled $3800-$5500 (and beyond).
      Rebuild interval is a contentious subject, but I would say 25hrs on a top end and perhaps two tops before changing the bottom would be a good rule of thumb. Many claim to run their top ends much as 50hrs in a stock moto when being used as a practice donkey, tread carefully there.  Like I say, opinions as well as situations vary a lot. If you are running hard and competitively look at changing top end every 5hrs or so.
      I think most would agree that running a quality leaded racing gas and racing oil will help ensure the motor stays in good shape, especially those bearings that you cant inspect visually down the bottom. Periodic inspections of the internals of any motor that’s having the living daylights revved out of it is a good idea.
      Provided your cylinder is still in good shape you could do a top end yourself and have change out of $150.
      Chassis wise, if the Birel or Corsa range is working for you with your existing fleet and you have good contacts and support, I think stick with those brands.
