--> Stock Geometry Caster/Camber – ekartingnews
Home Forums Chassis & Handling Stock Geometry Caster/Camber
This topic contains 2 replies, has 2 voices, and was last updated by  Patrick Roth 3 years, 10 months ago.
  • #28999
    Evan Fraser
    Hi EKN,
    I run a 2006 CRG Road Rebel with the 8-position caster/camber pills top and bottom in the yokes.  What I’m wondering is if anyone knows what the measurement of caster/camber is in the frame geometry, with the kingpin running straight from the top of the yoke to the bottom with no adjustments made with the pills.
    Obviously I can take a measurement with my snipers but I’m certain that my yokes are bent.  I’d like to know what I would see on the snipers if my chassis were fresh from the factory.  If anyone knows that would be a huge help.
    Thanks guys!
    Evan Fraser
  • #29633
    Evan Fraser
    No one?
    If you put yoke lasers on the chassis, should they be pointing dead straight at each other with no deviation?
    By Yoke I mean the C-section, where the Kingpin goes through so you can check the inclination of the kingpin at the front hubs.
  • #29634
    Patrick Roth
    While I can’t answer your question I certainly can refer you to people that are more than likely able to help.  Give CRG USA a call at (970) 256-0109 or (855)-TEAMCRG.  Super nice people to deal with!
