Home Forums Tech Talk Standards for checking Dellorto jet orifice size
This topic contains 3 replies, has 4 voices, and was last updated by  John Kwong 2 years, 2 months ago.
  • #27665
    Chad Harrington
    Where can I buy a set of standards to check dellorto  PHBG 18 BS carburetor main jet orifice.
    I have main jets from 80 to 100 and suspect some of being the wrong size for their markings.  I need precision set of standards to check the orifices.  Can anyone help?
    #27710
    We flow tested for consistancy and found that all the Dellorto jets are slightly different. Some are way off. If you suspect you have jets of the same # that aren’t the same your probably right.
    Rick Williams
    Brian Degulis if it’s not asking to much would you explain how you flowed your jets please.
    #56121
    John Kwong
    Hi Chad,
    You can use a set of pin gauges to check all of your jets.  Here is an eBay auction for those:
    http://www.ebay.ca/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR10.TRC2.A0.H0.Xpin+gauge.TRS0&_nkw=pin+gauge&_sacat=0
