--> Standard chain Vs O-ring chain – ekartingnews
Home Forums Tech Talk Standard chain Vs O-ring chain
This topic contains 2 replies, has 3 voices, and was last updated by  TJ Koyen 2 years, 4 months ago.
  • #57274
    Andrew Byrne
    Big area for argument at our track, I hear pros and cons about both.   Standard chains are massively cheaper, they have the least rolling resistance on the stand and are easiest to set the tension, although they stretch allot more and faster, and of course they were out and break faster.   O-ring are stiffer on the stand, but loosen up when they get hot.  They are much more expensive but last way way longer, although they are harder to tension because they quickly develop tight spots.    Looking for opinions on they topic
  • #57282
    Greg Wright
    What engine are you running, a TAG or Rotax almost has to use o-ring chain, other classes it’s mostly just an extra expense.
    Greg Wright
    Rapid Racing Inc.
    Vintage B-Stock Pilot
  • #57354
    Agreed with Greg. O-ring for TaG applications, standard chain for anything else.
