Home Forums Tech Talk sr-y pipe flex length
This topic contains 4 replies, has 4 voices, and was last updated by  tony zambos 3 years, 11 months ago.
  • #23815
    Cory albright
    Hey folks, I’m new to karting this season and will be running sr y pipe. My question is what length flex is everybody running? I know what min length is, so should I start there or go a lil longer?
    Thanks, Cory albright
    #23910
    Bryan Williams
    mine is 6 1/4 inch. it was cut by the local kart guy to make it legal for our local track. So not sure if that’s a standard or just our tracks thing. Also I thing the longer it is the more power you get. I am semi new also so I wouldn’t take my word for gospel, its just what I have.
    also fyi I am running a kt100. not sure if that pipe goes on other motors also.
    #24029
    These pipes fall flat early. Run it as short as allowed to try and get some top end out of it.
    #24359
    Bryan Williams
    so the shorter the flex length the more top end you will produce?
    #24361
    you are correct and longer flex for the bottom end. do you know how to measure the flex length?
