Home Forums Tech Talk Sniper Pills
This topic contains 5 replies, has 3 voices, and was last updated by  Rick Brown 4 years, 7 months ago.
  • #22658
    Rick Brown
    I have an 04 CRG Kali it has 8mm kingpins with the 8 hole pills (top and bottom) what do I have to do to put the Sniper pills on it? do I need 2 sets or can I use what I have on the bottom in the neutral position?
  • #22663
    Mike Bray
    I just installed these on an Arrow X1 and they are great.  It’s your choice as to whether you install on the top only or both top & bottom.  Most are only on the top.  Things to know, the hole in the chassis yoke has to be 22mm, I had to buy a reamer and open them up, at least on my 10mm kingpin ones.  You have to drill & tap 2 M4 holes for each adjuster base to bolt it to the frame.  And my kingpins were too short with the Sniper units installed and I had to buy shoulder bolts and drill them for a cotter pin.
    After all that though I love them, very quick and easy to adjust.  With my Sniper lasers I set the toe and camber in about 5 minutes from scratch.
  • #22672
    Rick Brown
    Thanks Mike! What are you using on the bottom? Did you buy a centered pill or are you using an adjustable one?
  • #22703
    Mike Bray
    Just a centered pill on the bottom, I don’t need too much adjustability.
  • #22813
    Make sure the yoke  (part where snipers attach) is wide enough to mount the snipers some are not.
    I like them I have them on top only and get more than enough range of adjustment.
  • #22859
    Rick Brown
    Thanks Brian!
    From what I’ve read the snipers for 8mm kingpin need a 22mm hole for the pill. Anyone know if that’s correct?
