--> Sniper Grid – eKartingNews
Home Forums General Karting Discussion Sniper Grid
This topic contains 6 replies, has 5 voices, and was last updated by  Evan Fraser 3 years, 1 month ago.
  • #47499
    David Carrier
    Does anyone know the size of the squares on the Sniper V2 grid or able to measure them on their set?  Working on some math and curious as to what the sizes are..  Thanks!
  • #47511
    Each line is 2mm. So the dots in the middle of the boxes represent 1mm.
  • #47516
    David Carrier
    Thanks TJ.  However, I am looking for the actual size of the boxes, not what the boxes represent.  If you measure the box, it’s not actually 2mm on each side.  The 2mm is only true as far as the measurement due to the distance between the snipers.
  • #48035
    Evan Fraser
    TJ:
    It strikes me that the 2mm per box rule wouldn’t really hold though as the deflection of the laser would be greater or lower depending on how far apart the lasers are.  Like sticking it on the end of a spindle would make it appear to have more toe than if the laser were placed on the inside of the spindle.  Or different types of spindle!
    I guess what I’m wondering, if it’s 2mm per box where are the lasers located?
    Evan Fraser
    #43 - Formula K FK01 / Briggs LO206
    West Coast Kart Club
  • #48067
    Rob Kozakowski
    Evan, you’re correct that it isn’t an exact 2 mm measurement.  But it’s close enough that any difference will not be extremely meaningful.  Your best bet to provide the most precision is to take the measurements consistently at the longest distance possible (outside end of the spindle).
    When the odds are that your wheels may not be “exactly” straight ahead, when the tie rod sees a tiny bit of adjustment when the ends are tightened down, when the kart flexes on the ground, etc.  All of these things make having an exact measurement next to impossible.
  • #48154
    Evan Fraser
    Excellent point.  Thanks.
    Evan Fraser
