--> Sniper Camber/Castor Adjusters ? – ekartingnews
Home Forums Chassis & Handling Sniper Camber/Castor Adjusters ?
This topic contains 2 replies, has 3 voices, and was last updated by  Stewart Willis 4 years, 4 months ago.
  • #12533
    Keith
    Do you need two set of the sniper camber caster kits? What goes on the bottom?
    Thanks Keith
  • #12535
    You leave the stock bushing on the bottom, you shouldn’t need more than just the tops to adjust…  If you need more caster, roll the bottom eccentric to the forward most position, or more camber, roll it to the inside, or outside etc…
    CR
    XV Racing Products
    http://www.xvengineering.com/
  • #17744
    Stewart Willis
    My Hero Cadet came with a zero pill at the bottom.  For the rain, we added an eccentric.
