Home Forums Tech Talk small cracks in tire sidewalls?
This topic contains 2 replies, has 3 voices, and was last updated by  Jim Russell, Jr 4 years, 7 months ago.
  • #5086
    Charles Stuart
    I have some older MG Yellows and I recently noticed the sidewalls have several very small cracks in them. Is it time to throw them away? (There is still plenty of tread on them so I want to make sure before I do)
    William Martin
    That’s sun/air exposure. Keeping them in a dark sealed bag helps the “shelf life” quite a bit. Personally, I would not put them on the track…but I do use them on my kart stand!
    Jim Russell, Jr
    If these are at the tread rubber sidewall junction they are not a problem at all. Time and exposure to things like ozone lead to the drying of the rubber and small cracks appear in this area where small amounts of the sidewall rubber and tread rubber combine in the vulcanizing process.
    If the cracks are in the main part of the sidewall this can be a bigger issue and the tire shouldn’t be used. Air leaks can develop.
    If cracks are in tread rubber themselves then tire has most likely been exposed to tire treatments and it has degraded the rubber and should not be used.
    I have used tires with joint cracking many times.
