--> SKUSA pipe feedback – ekartingnews
Home Forums Shifter Karts SKUSA pipe feedback
This topic contains 23 replies, has 12 voices, and was last updated by  Chris Bany 4 years, 8 months ago.
  • #9563
    andy graham
    been looking at the new skusa pipe for my stock moto, wondering what kind of results its providing with the 99 style cylinder as opposed to the R4.
  • #9565
    Matt Dixon
    Lets just say at last weekends ProKart race all I saw on the grid were R4’s….
  • #9570
    MikeGoebel
    I’m pretty sure that the Musgraves were using the SKUSA pipe.
    S4……1st
    S1……1st
    Not sure which cylinder they were using but I’d bet it was the 2001
    Mike G.
  • #9583
    Howie Idelson
    +1 SKUSA Pipe.
  • #9611
    Chris Hegar
    I thought the SKUSA pipe was required now days.
  • #9651
    ^ not until next year. Can still run the R-4 until end of this season.
  • #9657
    Mark Tardif
    Anybody know anything about breakage?  My buddy and I purchased two SKUSA pipes when they first came out and both are already cracked in the bend??  Had an R-4 for two years with no problem, need a little help here.   MARK
  • #9662
    Troy V Smith
    SKUSA pipe should be under warranty for 6mo. I believe.  Each should be engraved with a serial number, which should also be on your purchase receipt – might look at your warranty options from the seller?
  • #9665
    Jimmy McNeil
    Contact the company you bought the pipe from  They can tell where to ship the pipe to have it repaired. We had one break, shipped it in and they welded a steel plate over the crack.
  • #9686
    Good thing SKUSA fixed that problem :)
    CR
  • #9702
    andy graham
    uuuuhhh, nice warranty work….NOT!
  • #9703
    At least it has a warranty……
    CR
  • #9704
    andy graham
    Chris — as a fabricator, would you consider that type of repair “acceptable” if it was your pipe?  Just wondering….why wouldn’t they tig weld it instead?  I had a similar problem with my 95 CR125 back in the day….a hole blew open in my pipe during a moto, the bike only had a few hours on it at that time…my dealer called Honda on Tuesday (closed on Mondays), they told the dealer to collect the pipe and send it back to them.  Two weeks later I received the pipe back repaired…I was amazed at how they were able to weld it up without having to put a plate over it.  To this day ive never seen a weld job that impressive.
  • #9705
    I’ve worked in manufacturing plants for more years than I like to share, generally speaking,  if it’s cracked and you weld , it will crack in the same spot or near it.  Putting heat into it from welding, weakens the material, Jimmy didn’t elaborate, but I would have to guess they welded the crack shut, THEN put a patch of metal on top to strengthen the area…  That IS how I would do it for a customer…..
    CR
  • #9712
    andy graham
    I’m not a fabricator or welder (but I did stay at a Holiday Inn Express last night), but Ive heard that drilling either side of the crack and then building and filling the crack with a tig welder is the proper way to fix this problem…I’ve seen several fixed this way and have not failed for a second time.  Maybe I’m hung up on the cosmetic appearance of a plate welded onto a pipe rather than an additional tig welded crack. …but hey, if it works, what the hell, right?
  • #9736
    Andy, that’s called “stop drill”, the first time I saw that was an aviation application where a crack in the plexiglass is drilled to keep the crack from propagating.  If it’s welded properly, it won’t propagate from that crack, ie, welded all the way through.  What will happen, is that it will crack near that area because the metal has been weakened from the welding heat.  You could also normalize the area after welding it, but that’s not a guaranty.
    A repair for my own pipe I heat the area up with a torch to clean off the inside, let it cool down, run a back purge, set the heat a little hotter on the tig so the weld speed is faster, and zip it up quick….
    Everybody has their way of doing things, a manufacturer, doesn’t want to see it come back again….
    CR
  • #9776
    andy graham
    thanks for the lesson Chris, I understand all of that clearly and completely…and you’re right — the last thing a manufacturer wants is to have to fix a problem product more than once thats for sure.
  • #9778
    Chris Hegar
    If it has a warranty I would think a cracked pipe would be completely replaced at no charge. At least that’s what my wife expects when returning defective items to the mall. She gets new pipe when she needs it!
  • #9781
    Jimmy McNeil
    wasnt thrilled with the plate but its better than nothing. from what I heard at the track last weekend, all pipes are going to have plates welded on them from the factory. Don’t know  for sure if that’s true, but that’s the story floating around the pits.
    Btw, this new site hates my iPhone :(
  • #9789
    Andy, you’re welcome, hope that helps…
    Hegar, why is it every time somebody talks about a crack pipe, you chime in? :)
    Jimmy, I would be happy if they fixed the quote button/buttons!!!
    CR
  • #9790
    Howie Idelson
    I believe the pipe is now being shipped with a reinforced plate at the bend. Also some new mounting points.
  • #9802
    Chris Hegar
    Pipes and kart racers, what’s new.
  • #10424
    Chris Bany
    Has the SK1 pipe proved to level, or even out, the ’99 vs ’01 cylinder discrepancy?
  • #9959
    Josh Buttafoco
     photo A01CCAEE-A1C0-4EE8-AFC0-4F18CBA3D769-42570-0000162C734018A3_zps62ba4057.jpg
     photo E69E934F-92D0-4ABD-8A17-C1C2EEB681F3-42570-0000162C6D9395B8_zpsffa704fd.jpg
     photo 2F627E29-CCC1-419B-ABD5-85CB29F97E68-42570-0000162C77F988B7_zpsb5365dfe.jpg
