Home Forums Classifieds Classifieds – Parts SKF 30mm ceramic bearings
This topic contains 4 replies, has 2 voices, and was last updated by  Andy Paszkiewicz 2 years, 11 months ago.
  • #28804
    Andy Paszkiewicz
    SKF 30mm ceramic rear axles bearings.These are out of our 2nd kart we were gonna run KPV Sportsman with.Change of plans and no longer need them.They are in excellent condition and were used maybe 4 weekends.
    They are $200 each plus shipping new.
    $300.00 shipped email andypasz@yahoo.com
    from SKF website
    The patented ConCentra Solution allows centering of the shaft and its rotation, in respect to the bearing center. The bearing has a removable snap shield that allows to easily clean the bearing and re-lubricate it after each use. The patented profile of the outer ring has been designed to avoid the risk of misalignment to the unit support. The bearingis available with ceramic balls that help maintain low friction while reducing the rotating mass and increasing stiffness.
    The unit does not need modifications to the housing/cassette, so it is retrofitable to existing factory designs.
    The external patented profile of the Outer Ring SKF Kart Unit has small grooves with sharp edge along them. This particular geometry increases the resistance to the misalignment of the bearing in respect of the cassette when driving the Kart. The SKF geometry assures the bearing much more grip inside the aluminium/magnesium cassette.
    By using ceramic balls it is possible to decrease friction, weight and increase hardness with the result of lower running friction even with little quantity of lubricant.
    #28805
    Andy Paszkiewicz
    #28864
    Howie Idelson
    Are these in good condition?
    #29665
    Andy Paszkiewicz
    Sorry Howie was out of town and not checking the post.The bearings are in excellent condition and not a single issue with them.Just no longer have a need for the extra set.
    #30242
    Andy Paszkiewicz
    Sold thanks EKN
