Home Forums Shifter Karts Silicone hoses for KZ?
This topic contains 3 replies, has 2 voices, and was last updated by  Matt Martin 1 year, 9 months ago.
  • #66397
    Greg Cavouras
    I am looking for a set of silicone hoses for my TM.  I am aware of the MRC kit but I don’t think it will fit because it appears to be configured for the X30 which has the lower coolant port above the crank, whereas my TM has it at the very bottom of the engine.  Anybody have a source for the correct hoses?  Thanks.
    #66403
    Matt Martin
    I haven’t seen any silicone sets.  Assuming you have a K9 of some sort, #18 here is what you need.
    TM Cylinder – K9B/C
    #66430
    Greg Cavouras
    Thanks but it’s not the bypass hose I’m looking for, it is the hoses that go from rad to water pump to engine.
    #66431
    Matt Martin
    I don’t think there is a kit.  Most folks just buy a long section with a 90º bend on one end, or use a coupler to attach bends with straight sections – to achieve the needed angles.
    however, this photo from Motoiq.com might help (it has a brand and part number)
    Link to full-size photo
