--> TM K9c F/S – ekartingnews
Home Forums Classifieds Classifieds – Engines TM K9c F/S
This topic contains 2 replies, has 1 voice, and was last updated by  Rod Balding 1 year, 6 months ago.
  • #72423
    Rod Balding
    Complete with carb , pipe , silencer , U-bend , mount , radiator and air-box
    New replated cylinder by SwedeTech , ports set to stock
    New top end – piston , ring , pin , bearing , cir-clips
    New bottom end by SwedeTech (crank pin , bearing , thrust washers and trued ) main bearings , all seals and gaskets
    New Rod with less than 1 hr run time
    New SwedeTech Carbon reeds
    New clutch with less than 1 hr run time
    New FreeLine air-box
    Excellent KG Special Plus Ultra radiator with curtain
    New DellOrto jets , pilots , needles , emulsion tubes , float and needle and seat (a bunch)
    All transmission parts have been tumbled
    Newly re-plated extra K9c cylinder and piston
    Lots of spare parts
    This motor is in new condition , I bought it used with a fresh rebuild from IM and was ran less than 1 hr. by previous owner , I tore it apart and found the plating was thin around the exhaust is the reason for another total rebuild using SwedeTech for the plating and crank work . I have yet to put it on a kart and as stated , has not been fired since rebuild in June .
    http://s1103.photobucket.com/user/rtbalding/library/TM%20K9c%20KZ%20ICC%20Motor?sort=9&page=1
    $2800.00   Local pick-up or will meet within a reasonable distance or will ship at buyers expense .
    Contact    618-599-9379
    THANKS
  • #72895
    Rod Balding
    CR-80 **SOLD**
  • #73008
    Rod Balding
    TM K9c is **SOLD**
