Home Forums General Karting Discussion Shifter lever travel-question?
This topic contains 2 replies, has 2 voices, and was last updated by  Ed hodgson 3 years, 8 months ago.
  • #26359
    Ed hodgson
    Hello. I finished mounting my shifter lever on my chassis. It is mounted between my steering uprights. The tab that the linkage bolts to, passes underneath the right side upright.
    When I have this tab pointing directly at the right side frame rail (90 deg. to it) I have about 1 1/4″ travel in either direction (forwards/backwards) before it contacts the upright or fuel tank.
    Is this travel enough to allow proper gear shifts? I know the height of the J-arm will affect this also; wanted to ask on here.
    Thanks again for any and all information!
    Ed
    #26401
    Dave Holstein
    That sounds like more than enough travel, remember a shifter engine was originally designed To be shifted with a foot, it will vary slightly with different engines, and it’s a little different on up shift and down shift, but it should be ok with 1 1/4″ travel  at the shift linkage arm.
    #26415
    Ed hodgson
    Thanks for the reply!
    I’m pretty confident I’ll have the travel necessary to change gears, too.  First time building a shifter, I appreciate all the useful advice!
    ed
