Home Forums Shifter Karts Shifter engine linkage – how to bend…
This topic contains 3 replies, has 3 voices, and was last updated by  Brian Spek 2 years, 2 months ago.
  • #58408
    Brian Spek
    Putting a stock onto a shifter kart and looks like the long tie rod that connects to the shifter arm will need a bend in it.  Ideas on the easiest/safest way to bend these are welcome… thanks.
    Nick Galante
    Mock it up in your kart, then sharpie marker where you want it bent.
    Put it in a vise and bend once, then check. Repeat if necessary.
    You may need to make a couple of bends in a couple different spots.
    Try to have as little as possible. Measure and mark twice, bend once.
    I use a steel bar that slips over the rod to bend it in the correct spot.
    If it is Aluminum make sure you never over bend it, because aluminum doesn’t like to bend back, once it is bent in one direction. Steel is more forgiving.
    If you need to cut it, try to cut it on the right hand threaded side. It’s easier to tap ,if necessary. Unless you have a left-handed m8 tap.
    Matt Dixon
    +1 to what Nick said. I use a coat hanger to mock up
    Brian Spek
    Thanks. Worked great.
