--> Shifter Chain Lube – ekartingnews
Home Forums Shifter Karts Shifter Chain Lube
This topic contains 5 replies, has 6 voices, and was last updated by  Richard Kirlin 3 years, 6 months ago.
  • #33887
    Todd Kageals
    Guys,
    I have been using “Crystal Clear” chain lube or something like that because it’s what’s available at the local bike shop.  It seems to work well as I have never broken a chain and after two years, both of my karts chains still look to be in excellent condition.  Having said that, holy cow what a mess!  The “Crystal Clear” turns jet black and gets all over everything (including my clothes).  I’ve ruined enough shirts when working on my kart to pay for a new chain at every race!  I’m looking for an alternative that works as well but does not sling off all over everything.  I MAY be using too much of it, not sure.  I lube it whenever it looks like it’s starting to get dry.  Usually once a day at a road race and maybe twice a day if I am doing practice days with a lot of sessions.  Any recommendations?
    Todd
  • #33897
    Dale Daugherty
    I use Motul “Factory Line” Chain Lube. It sprays on fluid and clear, but dries tacky and waxy. It stays on pretty well, but still gets dirty, and still gets a fair amount all over the underside of the chain guard. Just the nature of the beast. I know a lot of folks use Tri-Flow, but I haven’t so I can’t comment.
    Sounds like what you have may be a bit too “fluid”.
    2010 Spirit [Birel] SP32 // SRS CR125 - Stock Honda [#08]
    Hill Country Kart Club - New Braunfels, Texas - http://daledaugherty.wordpress.com/
  • #33916
    Steen Carstensen
    Like Dale, I use Motul products as well, best stuff IMHO. When you apply the lube, spray onto the inside/ bottom of the chain, not the outside as it will fling off easier. Do not use a lot, just enough to wet the chain, but do it after every race when the chain is still hot.
  • #33988
    Clark Gaynor Sr.
    We use “Xeramic”, “Ceramic Synthetic Chain Spray”, and it is messy!!  And we lub the chain EVERY time the kart comes off the track.  Whether it’s a 5 minute practice or a 30 minute race- every time.  If your chain starts to look dry, you’ve waited too long to add some lub.  Oily and messy is fine, it helps your chain and gears live.  We get the stuff from Russell Karting.
    Clark.
  • #34179
    mike
    I use the C4 Factory Line on my kart and C2 Road on my bikes (street and race), although I might switch to using the Road lube on both when I run out of the FL stuff because it makes zero mess and is advertised for karts on the Motul site.
  • #34332
    Richard Kirlin
