Home Forums General Karting Discussion Seat Position on Tony Kart 950
This topic contains 2 replies, has 3 voices, and was last updated by  Walt Gifford 1 year ago.
  • #62078
    Mike
    Hi Everyone,
    Need a little help on positioning a new seat on a new chassis.  I have a Tony Kart Rookie 950 with M2 OTK seat.  My son is 54 inches tall, is there a chart anywhere of seat positioning?  I saw a chart by searching google but it started at about 20 cm taller than he is, probably on a full size chassis.  Any help would be greatly appreciated.
    Mike
    #62079
    Jeff Stone
    Mike,
    Send me an email, and Ill forward to you the Factory Set-Up sheet that has the seat placement dimensions…
    Jeff Stone
    jlstone_66@yahoo dot com
    #62199
    Put boards under the chassis and sit down with the seat and slide it around and tilt until you find a good spot. Then mark the seat struts with a sharpy and drill. Then put it on the scales and check for 50-50 side to side and 45-55 front to back.
