Home Forums Classifieds Classifieds – Parts Rotax/CR125/ICC/KT100 parts
This topic contains 0 replies, has 1 voice, and was last updated by  Mike Beeny 5 years, 3 months ago.
  • #12213
    Mike Beeny
    1-Mychron 3 Gold Ebox and gauge with Mychron steering wheel. (USED)
    Has not been used for several years but was in good working condition when removed from kart. Steering wheel is a little rough. Download cable included.
    $250.00
    1- Bullseye model B2 laser alignment system. Have had for many years but only used a few times. The Sniper B2 is the taller version of the original Sniper and can be mounted on 40mm hubs or 17mm spindles . With an adapter it can also be mounted on 25mm spindles but i do not have that part.
    $350.00
    1-Racejet weather pod (new) with race Jet software for Windows and palm version 1.10
    Includes MaxJet FR125 Max version 1.3, Modem cable for downloads, Instructions.
    Serial# 04RJ-DB9-R.D-240470
    $150.00
    27- RS125 piston rings (New, in OEM bag) P/N 13121-NX5-701
    $15.00 each
    1-Race Jet weather pod (used a few times) with race Jet software for Windows and Palm version 2.60
    Includes Maxjet FR125-Jr-MiniMax version 1.61a,modem cable for downloads, instructions
    Serial# 05RJ-DB9-REV.F251167
    $100.00
    1-ICC jet kit
    Mains
    118,120,122,124,125,126,127,128,129,130,132,140,142,145,148,158,160,165,168,175
    Emulsion tubes DP 260,DP 267, DP268, DQ 261, DQ 262, DQ 265, DQ 266
    Inner pilots B45, B50, B55
    #40 slide
    Needles K21,K22,U2,U7
    $65.00
    1-Horstman 3rd bearing support (style B) New in box.
    Fits Kt-100s and DAP T-50.
    $40.00
    1- Horstman 3rd bearing support (style C) New in box.
    Fits TKM piston port and Reed, Yamaha Kt-100
    $40.00
    1- Sniper castor pill set (new)
    Left and right side, top and bottom pills
    $75.00
    1-RLV R2 exhaust pipe
    Stinger has been straightened out to keep silencer from burning rear bumper. This mod did not seem to hurt or help performance. There is 1 small spot weld to cover a pin hole.
    $90.00
    Stock with no welds
    $110.00
    1-RLV C2 exhaust pipe
    Some welding work done on the header tube around the spring hooks.
    $100.00
    1-BRLV C5 exhaust pipe
    stock with no welds
    $150.00
    1-12″ adjustable/tunable M4 silencer (black type)
    Used for 1 track session. All tuning spacers included. 1″ ID inlet.
    $125.00
    1-12″ standard M4 silencer (silver type)
    This is an early silencer from around 2004 and has a good amount of use.
    $20.00
    1- 5132 R Elto ICC silencer (new)
    $100.00
    1-PVL ICC ignition coil p/n 105 458 (new)
    $50.00
    1-PVL ICC ignition stator/flywheel (new)
    $175.00
    2006 Maxter ICC counter gears
    2-16t,
    1-17t
    1-18t
    $5.00 each
    Buyer pays shipping. Pictures available.
    Contact:
    mikebeeny138@gmail.com
