Home Forums TaG Rotax Max rotax micro max fuel doesn't flow to carb
This topic contains 4 replies, has 4 voices, and was last updated by  tony zambos 2 years, 4 months ago.
  • #63070
    Tadas Ratkevicius
    Need help, just got used rotax micro max, never had before. Its non evo. Problem – gas doesn’t flow tube to carb, I blowed line, are good. Looks like is not sucking in, or pump doesn’t work. Engine was recently rebuilded, and should work. Its rather wiring or something else.
    Help.
  • #63107
    Christian Fox
    Your carbs floats are upside down, your needle is jammed shut and fuel can’t flow into the carb.
  • #63176
    Tadas Ratkevicius
    1. Where is that needle should be? How to get to it?
    2. and which floats upside down? Yoy mean pump?
    3. thanks
  • #63177
    Mark Traylor
    go to Acceleration karting and look at the exploded view diagram for the dellorto
  • #63274
    In addition to Christian’s and Marks’s comments;
    # Connect a piece of fuel line to the carb inlet. With the carb in its upright position, blow into the fuel line. If you can blow air into the carb, turn the carb upside down and blow into again. This time you should not be able to blow into the carb. If the carb passes this test, the needle valve should not be the issue.
    # If the test above fails, with the carb upright, rap on the side of the carb with the handle of a screw driver. This should dislodge the needle valve if it was stuck.
    # There is an internal fuel filter in the carb. Try cleaning that.
    # If you’ve done all of the above and still having issues, check your fuel pump. It may have assembled incorrectly or the fuel lines are attached wrong.
    Scour the internet for manuals and articles on the Rotax and the Dellorto carb That you can find. The first two are on me.
    http://www.karting1.co.uk/new-ThePreparation&JettingoftheRotaxCarb.pdf
    http://www.kartservice.nl/pdf/DOC_Handbuch_Dellorto.pdf
