Home Forums Tech Talk Rotax Max Advance Ignition
This topic contains 0 replies, has 1 voice, and was last updated by  pugtk 5 months, 3 weeks ago.
Viewing 1 post (of 1 total)
  • #85407
    pugtk
    Hi All,
    Just wondering is there any coils of any other models of kart engines/bikes that work on a rotax max which aren’t retarded at 12.5k?
    I’ve a mk1 rotax engine for fun and Im looking to get some more top end pull out of her.
    Ive seen a replacement coil which ahs a separate cdi box but its a bit pricey at €450
    Failing that would using a smaller sized crank sensor placed differently in hole work? as in retarding/advance ignition?
    Or using some form of resistor  between the coil and crank sensor to alter the power to the coil adjust timing?
