Home Forums TaG Rotax Max Rotax Hesitation Issue Help Required Please
This topic contains 7 replies, has 4 voices, and was last updated by  Samir Shah 1 year, 7 months ago.
  • #66947
    Shane Spencer
    Hi guys,
    I’ve just stumbled across the forum and wondered if any one can shed some light on an hesitation issue I’m having with my kart?
    Problem I’m having is the kart is really holding back and hesitating quite a lot, it seems be before the power valve opens, I’ve fitted these new parts to try to eliminate:
    New Power Valve kit
    Replaced the jet from a 165 to a 152
    New fuel filter
    New fuel pump internals
    New spark plug
    Charged the battery
    I did all these last week and the hesitation is still there, can anyone offer any info to help me out please?
    Thanks in advance.
    #66966
    Welcome to the forum.
    First, check your grounds. Then pull the carb and disassemble it. Take the needle valve out and clean the carb body thoroughly. Don’t get any cleaner on the needle valve. There is an internal fuel filter. Clean it out. Assemble the carb. Check for a float with fuel in it. Check the float heights. Last, be sure that the vent tube access the top of the carb has an opening in it.
    #66981
    Shane Spencer
    Hi,
    Thank you for the advice, the only thing that I haven’t done on the list is check the grounds and the float chamber heights.
    To be honest I’m unsure how to check the heights?
    Thanks again.
    #66988
    Keymaster
    Shane, check you private messages. Thanks.
    #66989
    Shane Spencer
    Sorted the name change I think.
    #67002
    Use the link below to download the jetting and power valve article by John Savage. John recommends a 3mm float height. That’s a good place to start. I used 4mm but I come from a road race background.
    Note: you can download the article but you won’t be able to print it.
    http://www.karting1.co.uk/jetting-karting.htm
    #67003
    Shane Spencer
    That’s a great link, thanks for that.
    #67795
    Samir Shah
    We’ve had an issue with the engine not revving consistently past 13k – Jr Max with EVO. I finally tried using 2 gaskets on the crank pickup. Amazingly, even on the stand, the engine sound changed, and it is now a lot better. We’ve only had 3 laps at the end of the track day with this change, so need to test it some more, but maybe worth trying.
    INFORMATION BULLETIN: Dellorto Ignition System -How to Assure Faultless Function
