Home Forums TaG Rotax Max Rotax Clutch Engaging at low RPM
This topic contains 2 replies, has 3 voices, and was last updated by  Steve piggott 1 year, 5 months ago.
  • #71098
    Anonymous
    Out of 5 motors, this one I recently bought (new style clutch) has a unique issue where the motor continues to push me into the corner even after letting off the gas.  The clutch grabs at low RPM’s in the pits as well.  I replaced the clutch, same problem.  Is it possible that the drum is not perfectly round and catches?  It spins freely when the motor is off, and the bearing is clean and greased.  Suggestions?  or anyone have a spare drum (user or new) that they want to get rid of?  Or is there another possible answer?  Thanks.  Brian
    #71133
    Mark Traylor
    Engine speed should never be so low on track that the clutch disengages. clutch engages btweem 4000-5000rpm leaving the pit lane and then pretty much stays locked up.
    #71168
    Steve piggott
    I would try different drum
