Home Forums Tech Talk removing arrow throttle cable auto lock
This topic contains 1 reply, has 2 voices, and was last updated by  tony zambos 3 years, 8 months ago.
  • #37578
    mike wu
    probably a stupid question, but does anyone know how to remove the throttle cable from this:
    http://store.kartsportna.com/product.php?productid=17543&cat=285&page=1
    I can tighten it buy pulling it but can’t pull it the other way.  That’s obviously by design but what am I supposed to do when I want to remove the throttle cable?
    thanks.
  • #37581
    Well this is probably a stupid idea. Loosen the curled not on the end, then unscrew the barrel. Guessing that there is something similar to a collet, similar to ones used on old Dremel tools, inside the barrel and once the tension is released, the cable should come out.
