Home Forums General Karting Discussion Remote tire temps?
This topic contains 5 replies, has 4 voices, and was last updated by  Walt Gifford 3 years ago.
  • #40496
    Ted Hamilton
    Anyone tried these out on a kart yet?
    http://www.drivenracing.com/embrace/mantis
    #40531
    Why does everything in karting cost 300 something dollars.
    #40536
    Greg Lindahl
    The challenge is that with only two sensing points all you’re likely to learn is how little you know about tire temperatures!
    To answer many questions would require a bare minimum of four points and much preferably twelve (inner/center/outer for all four tires) with GPS data.
    Don’t mean to discourage you but if you have the resources, go to a more complete data collection system with sensors (~$3,000.00).
    #40541
    Ted Hamilton
    Oh, I’m not looking to do this…just curious if anyone had seen ’em and tried.  IMO, a DRACK for a kart is silly.
    #40563
    patrick j slattery
    I would be happy just to be able to monitor my tire air pressure during the race.  Tire temps are great but a probe is the best way to get that and you can’t get to the tires quick enough after a race due to having to wait in line at the scales
    #40564
    In my situation of high CG and over loaded tires it would tell me what I already know. My tires start off too cold then slowly over heat. If I reduce pressure they still over heat plus feel mushy. I just set my pressure from feel then put up with whatever temp that brings on any given day. Usually means I’m stuck to the track with snap over steer and a ton of caster dialed in. If karts were only 15% bigger.
    I suppose you could move the sensors around over several track sessions or maybe just read the right front and rear.
