Home Forums TaG Rotax Max recommend someone for Rotax Carb cleaning and rebuild
This topic contains 4 replies, has 4 voices, and was last updated by  Scottie Melancon 4 years, 1 month ago.
  • #26445
    Max Blum
    I have two that I would like rebuild and cleaned… at some point I pulled them off and they were not right. would like to have the spares on hand for when the need arises.
  • #26451
    Finch Guenther
    Why not just download a manual and do it yourself?
    Finch Guenther
    #51 CRG KPV
  • #26461
    Max Blum
    I think it needs to be deep cleaned… or is that just simply being naive… I think I even have the gasket kit and the parts, just never did it… you are right.
  • #26685
    Eric Alexander
    Buy yourself a sonic cleaner from Harbor Freight for cheap (like under $50.00).  Then break down the carb and let the sonic cleaner do its thing on all the parts except the needle and the gaskets.  I do this on a regular basis using dawn dishwater cleaner.
    • #27160
      Scottie Melancon
      That’s how I do it. After the bath, I blow high pressure are through it then hit with carb cleaner. Make sure to soak a Q-tip in WD40 and swab the float valve seat. This helps prevent the valve from sticking which could be real Bad.  Also, never use a solvent with the ultra sonic bath.  Us a mild  liquid detergent.
