--> Rear Axle collars? – ekartingnews
Home Forums Road Racing Rear Axle collars?
This topic contains 5 replies, has 5 voices, and was last updated by  Cliff Brannon 1 year, 4 months ago.
  • #75667
    Tim Landon
    Trying to use as few as possible.  Do you guys collar the wheel hubs?  I dont see the need, or am I wrong.  Also dont see the need on the brake hub or the axle its self.  I’m thinking only on the axle clutch. ???? Thanks
  • #75668
    Greg Wright
    On an enduro I put axle collars on everything and I mean everything.
    Greg Wright
    Rapid Racing Inc.
    Vintage B-Stock Pilot
  • #75669
    I’d run one on each side of the left axle bearing to hold the axle stationary. The axle moving could cause your brake rotor to drag and at best slow you down. Worst case is the rotor exploding.
    And I’d put them inside the hubs to prevent the tire moving in and contacting body work or the chassis.
  • #75673
    Ian Krueger
    yes i use a total of around 9 or 10 to keep everything in place. Im actually considering making myself a set of beefy collars to hold my axle clutches in place because i have the space. Also I use blue loctite on the ones i move often, and red loctite on the ones around the brake rotor, axle clutch, just to be safe. Ive lost a couple before on track
    WKA sprint
  • #75675
    Tim Landon
    Geez, I wouldnt want to take an axle collar to the face shield at 100mph.  That would leave a mark!
  • #75680
    Cliff Brannon
    I tried to leave them off the wheel hubs once and the tire slid over and rubbed the rail ending my race.  Now I put them everywhere.
    B-Stock
    Formula100
