Home Forums Tech Talk Re-powder coating – engine stop mount question
This topic contains 7 replies, has 4 voices, and was last updated by  Walt Gifford 4 years, 3 months ago.
  • #33419
    Eric Alexander
    I’m prepping a 2008 CRG Kalifornia frame to be powder coated.
    I’ve got a question about the engine stop block mount.  I’ve removed the mount and stop bolt, the there are still two threaded sleeves in the frame holes.  The frame has four distinct height positions for the mount, so it appears these sleeves should be removable to change position.  But I can’t seem to get them out.
    Any advice here before I break out the hammer?
  • #33449
    FREDDY SANDOVAL
    Pictures please!
    Most of the time you can get away by using masking tape in all holes before you send out your chassis.
    But it would really make it a lot easier if you could post pictures of your stuff, to be able to help and advice you better.
  • #33454
    Eric Alexander
    Here’s some pictures to underline what I’m asking about.
  • #33462
    FREDDY SANDOVAL
    Eric
    Those look like inserts/timeserts
    They’re usually pressed in, as you can see most likely they were pressed in at the factory, at the desired hight.
    I would totally cover the holes with masking tape, or find 2 bolts of the same pitch, screw them in, or better yet find a bolt with a wide head that will match the flat side of the thread flush, screw it in, tape the end that will stick out the other side and remove them when powder coating is finished, cut and trim with a brazor blade some of the burr, left over paint so that it won’t chip away, not to mention it will look neat.
    Hope that helps.
  • #33463
    Eric Alexander
    Great to know. Thanks!
  • #33562
    Troy V Smith
    I just had a frame done with the same fittings. The powder coater used rubber plugs through those threads to protect them from the powder – very much like plumbers plugs. Don’t forget to cover and/or plug the internal face for your steering column uni-ball bearing and c-clip groove.
  • #33563
    Eric Alexander
    Absolutely!  Thanks Troy.
  • #33585
    Those don’t come out.
