--> QUESTION FOR THE YEAR – ekartingnews
Home Forums TaG QUESTION FOR THE YEAR
This topic contains 10 replies, has 5 voices, and was last updated by  Jim Russell, Jr 4 years, 5 months ago.
  • #16608
    Jim Silverheels
    Anyone have any idea why I have gone through 6 Leopard rotor/commutators  this past season? I’m not talking brushes but bad commutators. Put the continuity tester on the commy and will always find a dead leg. Yes I have double grounds and positive the commy’s are bad. When I tap the starter it will take off but if it gets stuck in the dead position, of course it wont go on the starting grid.. thanks
  • #16613
    Jim,
    That sounds very unusual.  No ideas, but a couple of questions.  When you find the bad commutator, are you replacing just the commutator or the whole starter? And where, if you don’t mind, are you purchasing the replacement parts?
  • #16616
    Jim Silverheels
    Tony, when the commutator goes I just buy a new starter. Don’t know if you can just buy a commutator. This has happened 6 times this yr. I’m positive there’s a dead leg on the commy. Once again did a continuity test on them. Yes it does seem unusual.
  • #16751
    Jim,
    Took apart a Leopard starter motor. Between any of the ten contacts, got about .7 ohms.  A couple of ideas. First, the insulation on the windings is melting do to extreme heat.  Possible causes could be too much current to the starter or maybe a poor ground.  Taking one of your busted starters apart and see if it smells like an electrical fire.
    The other possibility for the failure could be physical damage.  I’ll guess, since I have no proof, that if the motor was spinning without a load, that it could tear itself apart.  Could your starter motor still be running after the engine starts and the bendix has disengaged?
  • #16755
    Jim Silverheels
    Tony,
    No sign of burnt wiring… I always ask myself what the most obvious thing to cause this and the answer is vibration or a bad ground. I have triple grounds and the armature has no visible breaks. Polished up the commutator also. Always a dead leg on these 6 armatures that are bad. Don’t have the answer, darn it.  thanks
  • #16776
    Ted Hamilton
    Please post answer once you’ve found it…. you’ve piqued my curiosity.  I would’ve guessed faulty brush routing too much current through 1 comm leg or carbon bridging a comm leg…..  Be nice to know what to look for once I get my Leopard
  • #16786
    Jim,
    one last try.  Has the bendix ever been replaced?
  • #16793
    Jim Silverheels
    Tony,
    No the bendix hasn’t been replaced. It operates very easily by hand when I took it out.
  • #16808
    Just a thought that the bendix might be  hanging up on occassion.  With the ring gear about four times the size of the bendix, the engine turning 3k would have the starter spinning at 12K.  We’re rooting for you.  Good luck and keep us posted.
  • #16992
    Tim Koyen
    We replace our bendixes very frequently, since they seem overly prone to failure.  Perhaps Tony has a point?
  • #17099
    Jim Russell, Jr
    I have had several dead armatures over the years. If you spend the time you will find a broken copper winding wire somewhere in the mess. You can repair the wire and it will work fine till your repair breaks.
