Home Forums Tech Talk Question for the day
This topic contains 3 replies, has 4 voices, and was last updated by  Brett Staples 5 years, 2 months ago.
  • #12325
    Jim Silverheels
    Please go view this video and tell me why they drill the low speed jet passgae. You’d think it was for more fuel but of course all you would have to do is open the low speed needle more. thanks
    http://www.prd-usa.com/tillotson-hl-166-minimum-blue-print-for-use-with-prd-tag-controlled/
  • #12352
    Stephen barthelmass
    You drill it and open it more. If I had to guess its to get more flow without having to worry about it vibrating out. Also no matter how far you open a valve if the initial port is too small it will just lean out.
    Ive done this to 2 carbs  and the before and after is extremely noticeable.
    • #14243
      Brett Staples
      Hi All
      I have tried to open link but wont work, would someone be able to make this happen
      Thanks Brett
  • #12396
    Drilling that hole ensures enough fuel feeds the low needle before metering. Of course you have to pull the welsh plug to clean up because chips go everywhere.
