--> Question about WKA vs AKRA rulebook – ekartingnews
Home Forums Road Racing Question about WKA vs AKRA rulebook
This topic contains 8 replies, has 4 voices, and was last updated by  Ian Krueger 8 months ago.
  • #85784
    Ian Krueger
    1. Hello
    So I am planning on running the AKRA event this coming time at Pittsburgh PA. Anyone know of AKRA has any imprtant differences in rules such as body work, seat height from ground plane, or if they require steering fairings or anything you can think of , I have a curent WKA manual but if anyone knows any funny rules that are different, let me know! I’m racing Sprint Enduro (Yamaha)
    Or if the AKRA rules are available online? That works too. Thanks
    Ian
  • #85785
    Ian Krueger
    My ride is up to spec with WKA now so yeah I didn’t want to show up and be DQ’d but at the same time cannot find the rulebook online.
  • #85792
    Paul M. Petrun
    <p style=”text-align: left;”>Hi Ian, here is a link to dart karts website with the rule book.  http://www.dartkartclub.com/rules.html</p>
    Good luck
    Paul
  • #85805
    Ian Krueger
    THANKS!
  • #85820
    Bruce Peck
    Ian:  Assuming you are talking about the full body Yamaha/Piston Port classes such as WKA Sprint (or Piston Port Sprint for AKRA) – if you are up to snuff per WKA rules you’ll be fine for an AKRA race.  I don’t know of anything you would be called out for.  My little team has been running these sprints in WKA for years and more recently also at AKRA races like Mid Ohio and no changes are made.  Come to the Pitt race and have fun!
    Edit to Add:  WKA now has the backup throttle spring rule that I don’t think AKRA is requiring (yet) so that is something I know we will have to add before Daytona (note to self . . . )
  • #86030
    Ian Krueger
    Thanks Bruce.
    One rule I noticed that I don’t quite understand is the brake teather. Is this perhaps just a cable that acts as a backup from the pedal to the master cylinder(s)? The wording is a little unclear, and that’s the only thing I’m missing to pass Inspection at Pittsburgh. Thanks!
  • #86031
    FastCat60
    Ian:
    The brake tether is exactly that. It’s just a backup cable that goes between the pedal and the master cylinders to serve as a backup in case your brake rod disconnects itself and is pretty easy to install. Other than that item, as Bruce mentioned, the WKA and AKRA rules are basically identical for WKA/Piston Port Sprint with the intent of allowing you to cross between sanctioning bodies as easily as possible.
    -Adam
  • #86060
    Bruce Peck
    Ian: if you have questions about the brake tether send me an email (address below) and I can talk you through it.
    yamadog35@comcast.net
  • #86127
    Ian Krueger
    Thanks Bruce and Adam! Three cheers
