Home Forums General Karting Discussion Question about 2 stroke engine, excessive oil from pipe
This topic contains 8 replies, has 5 voices, and was last updated by  TJ Koyen 1 year, 4 months ago.
  • #71439
    Rod Hawkins
    I have a couple IAME KPV motors. Both only have a few races on them. One of them I have notices spews oil all over the place. It is slightly better when driving hard, but I had a buddy drive it and he was learning and it was really bad. But it is still much worse than my other motor or any motors my brother uses as well.
    Something else I notice is that when I first go out and the motor is cold, it takes several seconds to actually build the RPMs and start to feel the motor pull. After a couple laps, it seems like it is fine (besides the excess oil) but EVERYTIME I just start out on the track, it takes a while to get the power, almost like it is flooded or something?
    Sorry if this is the wrong catagory, but there isn’t a KPV section, and I would imagine that most 2 strokes have similar problems and characteristics.
    #71443
    Rod,
    The bottom line is that motor probaby needs to go into a shop. A worn ring, piston, cylinder or all of the above. Assuming you have the same type plug in each engine. You try a new plug, properly gapped, and see if that helps.
    #71445
    Rod Hawkins
    Rod,
    Tony, thanks for the quick reply. Problem is that it has done this since I had a new top end done. So thats why I was thinking maybe it might be something else, carb? Plug? etc…
    It very well could be that it wasn’t rebuilt properly, which I hope is not the case, since it has done this since the rebuild and since it is my back up motor, that rebuild was done over a year ago, and probably hard to take it back to the builder and say he did it wrong. I did see him at the last race and asked him about it and he attributed it to my newbie buddy not driving it hard, but as I look back at it, I realize it has been this way with me driving as well, but it was so long ago, I just forgot.
    #71448
    Maybe it’s just running real rich? What are your carb settings?
    Could be the ignition is too far back.
    #71458
    Certainly take Walt’s advice. Try swapping the carbs between motors. And I’ve that engine builders are human. Work with him.
    #71600
    Rod Hawkins
    Just noticed that my high needle was almost 1/4 turn out and low was about 2 1/4. I guess I need to close it to 1/8 or less and run it.
    #71641
    Matt Dixon
    Walt is on point. Sounds to rich. Make very small adjustments the high, bigger on the low.
    I used to tune to the color of the header, a nice tan color. White to lean black to rich.
    94y
    #71691
    Rod Hawkins
    for the KPV is there a “standard” setting for these needles (at a certain temp and elevation) or is every motor a little different and you just have to play with it to get it perfect?
    Sorry for the dumb questions.
    TIA
    #71751
    Depending on what exhaust you’re using, it could be slightly different, but we ran them with the 2, 3, and 4 pipes and the settings we usually ran on the carb were between 2 and 2.5 on the low at speed, and about 1/8 on the high. Usually you have to have the low around 1-1.5 at start up to get it to pull off the grid without bogging down, and once the RPMS start to come up as you leave the grid, open it to 2-2.5.
