Home Forums General Karting Discussion pyrometer. Infrared or probe?? brand?
This topic contains 2 replies, has 2 voices, and was last updated by  Sebastian Sarmiento 3 years, 7 months ago.
  • #37959
    Sebastian Sarmiento
    Just barely learning about tire temp and pressure, first thing while reading info here and there  is to get a good tool.
    What do you guys recommend? longacre seems to be the most common one, if so, which model?…
    Also, if you guys have any recommendations, table or anything that can help with the relation between track temp= tire temp= tire pressure/caster/camber adjustment I’ll appreciate it. Anything you know about it for small as it can be, it will be new to me.
    Thanks in advance.
    I wish you twice as much of whatever you wish for me. : )
  • #37985
    Gary Lawson
    Any probe model is fine. Infrared can be misleading and surface temp changes quickly
    Longview is fine
  • #38028
    Sebastian Sarmiento
    Thank you Gary,
    I followed your advice and got a probe one.
