--> Pump Around overflowing – ekartingnews
Home Forums Shifter Karts Pump Around overflowing
This topic contains 7 replies, has 3 voices, and was last updated by  Carlos Perez 4 years, 5 months ago.
  • #15106
    Charles Stuart
    I have a Kawasaki KDX200 shifter kart with a Keihin PWK 36 that has the pump around mod with the dual Mikuni round pumps.
    The system was overflowing pretty bad so I rebuilt the return pump but it is still happening. I had it running on the stand and I removed the tank cap I could see the fuel being returned but it obviously isn’t keeping up.
    Anything else I should try, any suggestions?
  • #15114
    Gerry MCN
    the return pick up is set to high or if it does it only when the tank cap is on the you are not venting enough air from the breather line on the tank
  • #15119
    Charles Stuart
    Thanks Gerry. The overflow happens with the tank cap on or off. I took the carb back off and have it on the workbench right now. I can tap the return pick up down but I’m not sure how far or where it should be. I’ve tried googling for pictures but no luck.
  • #15166
    Gerry MCN
    post a good pic of yours
  • #15179
    Gerry MCN
    return pickup is to low, but that is not that problem, try restricting the inlet,and you do have the vent tube plugged as seen here.
    http://eknclassic.com/viewtopic.php?t=78529&postdays=0&postorder=asc&highlight=inlet&start=30
  • #15180
    Charles Stuart
    My vent tube is not plugged and the inlet is not restricted. Ill see what I can do, thanks again.
  • #15176
    Charles Stuart
    (I already tapped it down a little bit but stopped when I realized I didn’t know exactly where it needed to be.)
  • #16028
    Carlos Perez
    I am a newbie in shifters and pump around, so it may not be the solution and I was lucky,  but I was experiencing the exact same problem and by changing the foam inside the carb did the trick. I have no more overflow…
