Home Forums Tech Talk PSA! Making a case for regular inspection of bearings!
This topic contains 1 reply, has 2 voices, and was last updated by  Walt Gifford 2 years, 10 months ago.
  • #44963
    Dale Daugherty
    Safety first! While cleaning the rear end, I felt a little bit of “grab” in the rear axle when spinning it, so I went about disassembling everything to clean and rebuild. Turns out it is a good thing I did, as the left side axle bearing was split clean across the inner race all the way up to the set screw. Disaster waiting to happen, I am sure.
    Broken Bearing Race
    Fractured inner bearing race. 50X80mm rear axle bearing.
    2010 Spirit [Birel] SP32 // SRS CR125 - Stock Honda [#08]
    Hill Country Kart Club - New Braunfels, Texas - http://daledaugherty.wordpress.com/
    #45253
    Ain’t never seen that before.
