--> Problems starting yamaha kt100 – ekartingnews
Home Forums 2-Cycle Racing Problems starting yamaha kt100
This topic contains 11 replies, has 6 voices, and was last updated by  Omar Calixtro 2 years, 10 months ago.
  • #49553
    Omar Calixtro
    I have a yamaha kt100 and I have recently installed a clutch on it. The thing is the kart started just fine on direct drive and now it won’t start with a clutch. It does pump fuel. Also if I choke the wb3a carb the engine starts then turns off. If I don’t choke it the engine doesn’t turn on at all. Am I doing something wrong? It would really help if someone gave me the steps on how to turn on a kart with a clutch.
  • #49555
    Peter Zambos
    It’s really simple. Engage starter shaft. Activate starter. Blip throttle. Disengage starter. You might have to choke the intake for a second if you just put a fresh carb on it.
    If you have to do anything else, then something else is wrong. Does the clutch and axle spin easily while the kart is on the stand?
    • #49557
      Omar Calixtro
      The clutch and the axle spin just fine.
  • #49558
    So it starts when you choke it? Do you then keep giving it throttle to keep it running and it still dies?
    • #49559
      Omar Calixtro
      I haven’t tried going full throttle. I say I go about medium throttle. Should I give full throttle or very little throttle?
  • #49575
    Omar,
    Was anything else done to the motor besides installing the clutch?
    How did you hold the crankshaft stationary while tightening the starter nut on the clutch?
    • #49576
      Omar Calixtro
      Tony, nothing else was done besides installing the clutch. I could check the carb. But I doubt thats the problem because if I choke the engine fuel does pump.
      • #49619
        Omar Calixtro
        Also I am using the inbuilt fuel pump on the walbro wb3a.
  • #49609
    Clean the fuel screen and put in a new pumper. Also could be a fouled plug from running rich on the stand.
  • #49617
    Omar Calixtro
    I also noticed just now when I tried to start it again that the fuel had trouble getting up to where the fuel going in the carb. The fuel had problems going up once I stopped choking the engine
  • #49624
    Patrick Haney
    I had the exact same problem. When I cloaked the engine, the fuel would reach the carb. As soon as I took my hand off the intake, the engine would stall.  Problem? Fuel tank vent was clogged.
    • #49635
      Omar Calixtro
      Thank you patrick I will take a look at the fuel tank vent later.
