This topic contains 3 replies, has 3 voices, and was last updated by  ANGEL RAMIREZ 1 year, 5 months ago.
  • #71389
    ANGEL RAMIREZ
    prd fireball just do not run without battery, if the battery is charge runs just perfect as soon i disconect the battery it dies(like a rotax)
    any ideas?
    thank’s.
    #71415
    Curious why you want to run without the battery. Check your ground connections and ground wires plus the air gap on the coil.
    #71442
    Nick Strasbaugh
    The current PRD ignition requires a fully charged battery to run.
    #71444
    ANGEL RAMIREZ
    (The current PRD ignition requires a fully charged battery to run.) <b></b><i></i><u></u>
    that´s why, is a new engine with a bad battery
    i  did not want it to run with out a battery, is just that had to use the external starter and nothing.
    thank’s
