Home Forums 2-Cycle Racing PRD 100cc engine question
This topic contains 1 reply, has 1 voice, and was last updated by  Ian Krueger 1 year, 2 months ago.
  • #74320
    Ian Krueger
    Hello
    I have a PRD engine, 100cc air-cooled, not sure the exact model or year.
    Does anyone know if these things are close in class to an HPV or KPV? all’s I know is it has a Yamaha crankshaft, because it has that taper and we used to run it in piston port sprint a while back. I’ve never take it apart because it still runs fine mechanically.
    I’m trying to build a dual engine laydown , piston port, and I’m trying to figure out if it’s close to a Piston Valve motor?
    Any info is greatly appreciated, thanks! -Ian
    WKA sprint
    #74369
    Ian Krueger
    Update: it’s an RK100 , anniversary edition. Got a square exhaust outlet (rectangle I should say) and we ran the WB3 carb same as the yamahas
    WKA sprint
