--> Power Valve Problems – ekartingnews
Home Forums General Karting Discussion Power Valve Problems
This topic contains 3 replies, has 2 voices, and was last updated by  Rob Kozakowski 4 years, 9 months ago.
  • #4465
    racehero243
    I’m having an issue with tuning my power valve and I haven’t been able to figure out what the issue is. No matter how many clicks in (as well as fully closed) or out, my power valve kicks in at around 10,000rpm every time. I’ve cleaned the unit fully and changed the exhaust matting and nothing seems to work. Does anyone have any idea what could be causing this? Any help would be greatly appreciated.
  • #4467
    Rob Kozakowski
    If it’s opening at 10,000 +/-, you can turn it in/out all the clicks you want, that won’t change things by more than a few hundred rpm (fine-tuning, not big adjustment).
    Check this out… might give you some answers…
  • #4468
    Rob Kozakowski
    http://eknclassic.com/viewtopic.php?t=84715&postdays=0&postorder=asc&highlight=proper+power+valve+operation&start=15
    Sorry, I tried to add a link, but something didn’t work. Just copy and paste the link above.
  • #4469
    Rob Kozakowski
    Or just click on the link… the joys of learning a new forum…
