Home Forums TaG Rotax Max Power draw in storage EVO
This topic contains 3 replies, has 4 voices, and was last updated by  Scottie Melancon 3 years ago.
  • #49946
    Jerry Brown
    We have found that we are required to disconnect the positive lead on the battery for the new EVO. There appears to be a power draw with the switch on the Off position and each time we pull the Kart out – after a 2 day or longer absence, the battery is completely dead. Is anyone else having this issue and has anyone located the source of the power draw?
  • #50622
    David Flori
    Typical Bombardier…
    Have to do this on my seadoos as well…
    Fortunately for those it is actually advantageous, as I just put a plug for quick disconnect between uses, and pull the cells in winter…
  • #50636
    Matt Clark
    Had mine off charger for a couple days before yesterday’s race, no charging at the track was needed.
  • #51361
    Scottie Melancon
    We’ve never had an issue with it off. Do you have a Mychron connected to the battery?
