--> popping on deceleration – ekartingnews
Home Forums Briggs & Stratton 4-Cycle Racing Briggs LO206 popping on deceleration
This topic contains 3 replies, has 2 voices, and was last updated by  Marty Troup 1 year, 7 months ago.
  • #72116
    Marty Troup
    I seemed to pick up more popping from the exhaust on deceleration and also
    have picked up a small cut out after hard cornering.
    I have checked the exhaust for air leaks and reset carb float and valve lash.
    but still a few more than normal popps from exhaust and the miss seemed to just start but not on every lap. I changed the plug and no difference.
    Any help Please.
  • #72190
    Kacy Stahl
    Hi Marty. I’m not anywhere close to an expert, but i have had similar issues. Here are my experiences and what worked for me:
    -My engine would backfire on deceleration. The cause of this issue was a loose header bolt. I had to helicoil the bolt because it had stripped the threading in the engine head. After that, I didn’t have any more issues
    have picked up a small cut out after hard cornering. I have checked the exhaust for air leaks and reset carb float and valve lash. but still a few more than normal popps from exhaust and the miss seemed to just start but not on every lap. I changed the plug and no difference.
    – My engine would cutout through tight corners. I thought it was an issue with the engine. I reset my carb float, reset valve lash, etc. But the cut out persisted. The culprit was actually the chassis. My rear width was too narrow, giving the rear too much grip. The excess grip was causing my engine to bog and cutout through the tight corners. The cutout problem was fixed as soon as I widened the rear a bit.
    I hope this helps
  • #72405
    Marty Troup
    Thanks as I thought it was at first but bolts are tight but I will change out gasket. I see no evidence of any leak but I will try again to see if there are any leaks.
    Thanks again
  • #72451
    Marty Troup
    Found out when I removed the exhaust pipe to look for crackes the it was the gasket that had failed.
    but still have a miss or stumble off some corners some times not every time.
