Home Forums Shifter Karts PJ28 Carb setup
This topic contains 1 reply, has 2 voices, and was last updated by  Ben Lewis 1 year, 8 months ago.
  • #60001
    Timothy Strawkas
    Been running this carb setup to get used to the Kart. It is A Slightly modded  Motor.
    keikin PJ28
    H 195
    L55
    R1368M needle
    Runs good, Have A hard time starting some times. I use the rope around the tire. If I try to push start it usually floods. Have to crack throttle. So I think overall it may be rich. I Am going to order A few different jets up and down , but was wandering if I should change the needle? This needle doesn’t seem to be on any Karting recommended pages, but it is A factory needle.
  • #72859
    Ben Lewis
    I know I’m late to the game on this post but for anyone else who looks at this down the road for reference:
    Throw the PJ away! Or sell it on ebay. You will always have issues.
    Get a PWM and start with (Sea level):
    DGJ needle 2nd clip (never move clip its good at 2 forever)
    M168 65-75 degrees
    M165-162 80-100 degrees
    Pilot 54-55
    *These are baseline ref only
    You can sometimes pick up a cheap PWM by searching for a mid 90s YZ250. I think they also came on a few other bikes stock. Also, a common mistake is to give too much gas when push starting. Don’t give it any until you hear bah dump dump and then only give it a little. And never ever pump, you will flood it every time.
    Make sure your throttle adjustments are set so that without pushing the gas pedal there is just a crack of opening between the slide and barrel. Just the teeniest bit.
    Sorry to sh** on the original question but I’ve messed with the PJs before and its just not tune-able esp with a kart pipe.
    " Turd Ferguson is real and he will pass your a** "
