--> Parilla Leopard Starting Problem (Help!) – ekartingnews
Home Forums TaG Parilla Leopard Starting Problem (Help!)
This topic contains 6 replies, has 5 voices, and was last updated by  Sean Swisz 4 years, 2 months ago.
  • #17797
    Daniel McBride
    I recently rebuilt the top end of my leopard, and it will now not crank properly.  The bendix briefly engages, and then immediately engages while still spinning freely.  Here’s a video:
    I have replaced the starter, bendix, and battery, still with no luck.   I’m completely stumped, does anyone have any ideas about how to fix it?  The only fix I can think of is to do the ~$700 digital ignition conversion.  I guess I could also purchase an external starter, but I’d prefer to fix this one since I don’t always have folks with me at the track.
    Thanks in advance for the help!
    Daniel
  • #17802
    Matt Dixon
    When we had that issue in tag it turned out to be the wiring harness. See if you can borrow a known working one before replacing.
    Will it start with an external starter?
    94y
  • #17808
    Daniel McBride
    Thanks for the suggestion Matt – I think I’ll try to run a new starter wire tomorrow and see where that takes me.  Not sure about the external starter (don’t have one), but that’s probably a good avenue to pursue if the new wire doesn’t fix it.
  • #17815
    Valdi Susko
    I had a similar problem, but mine was fixed by a good overnight battery charge.
  • #17818
    Valdi Susko
    Not sure if this would cause it, but might want to check-
  • #18091
    Jim Derrig
    Dan,
    Seems like your starter is seeing too much load and is disengaging.  Pull the spark plug and see if the engine will crank with no compression.  If not, you’re looking at some sort of internal engine friction.  Try and turn the motor using with a socket wrench on the sprocket nut.  If it won’t crank that way you might have assembled the top end incorrectly.
  • #22331
    Sean Swisz
    Sounds like you need to charge the battery. I had the same problem along with the start button logic board being bad. When the battery is even a little be below full charge it doesn’t want to start…esp in cold weather.  Give it a charge and let me know
    Tony Kart / Leopard
