Home Forums Chassis & Handling OTK Fernando Alonso Kart, very bouncy, hopping, Please help
This topic contains 9 replies, has 6 voices, and was last updated by  Ted Hamilton 3 years, 4 months ago.
Viewing 10 posts - 1 through 10 (of 10 total)
  • #31602
    FREDDY SANDOVAL
    My Son and I race at a very tight sprint track, at a club level home track
    We did pretty good with a 2010 Top Kart KT100, but now decided to switch chassis to a newer 2011 FA kart/ OTK with KT100 also
    We’ve been chasing a hopping problem, we narrowed the front track, widened the rear track, retightened front nerf bars at bumper, retightened front torsion bar, played with many different air pressures
    All that seemed to help a little, but I noticed my boy still struggles a little
    This only happens at our fastest double sweeper corner
    We currently run a spec tire Bridgestone YLC
    We run the OTK MX something wheels? Neutral axle, camber and caster is also neutral, the kart gets sniped aligned every race
    Can someone please chime in and tell my what I need to do?
    I told my 17 year old boy who happens to be an excellent driver, to quit driving the kart like a TOP KART, so the poor guy tries 3 different driving styles, but just can’t get the kart to glide smooth through the big sweeper corner.
    Please help! Anybody with OTK kart experience
    Thank you, in advance, FASTFREDDY.
    #31615
    It very well could be a matter of driving. It definitely is a different feeling kart and takes some getting used to all the positive front end feel it has.
    You’re going the right way; taking front width out and adding rear width.
    What front bar? The blade? If so, is it flat (horizontal)?
    The OTK kart has two sets of wheels; MXC and MXP. MXC are used by the majority of drivers at a regional/national level because they remove grip from the tire and keep the tire cooler over a run, resulting in a more consistent feel. MXPs are the stock wheels which are used in low grip situations because they do the opposite.
    The kart shouldn’t really hop badly on YLC and with all that grip removed.
    What are the actual front and rear track widths at this point?
    #31622
    My kid went from a DR to a Tonykart and had the same problem. It was driving. He had to get used to less wheel input in the Tonykart. If you have a Gopro you’ll be able to see it if that’s the problem.
    Matt Dixon
    If its only 1 corner have your boy straight arm the kart in that corner. Push with arm against the wheel and opposite heel on the heel stop. That should settle that down and keep you from tuning out the rest of the track.
    94y
    #31630
    FREDDY SANDOVAL
    Thank you all for your input, we’ve been working on different driving styles, and are fully awared of sensitivity steering, and we also know that OTK’s are very soft and sensitive.
    All of you guys are right, we’re trying all we can, including different driving lines and styles
    The rear width was at 45″ we brought it out to 55″
    Front had big fat spacer and 2 small spacers ( we removed fat spacer, and placed it outside)
    Front torsion bar is the oval shape tubing kind, not blade type ( it is horizontal, flat against floor pan)
    Please note that all the adjustments we’ve done, like retightening of front torsion bar, front nerf bar, rear track to 55″ all remains to be tested, I still don’t know what the result will be till this weekend ( race day ) Not much time to test. Lol. I just wanna be able to glide smoothly, with out bouncing/hopping so much.
    Do these karts like high air pressures?
    Thank you all, again for your help.
    #31635
    My guess is those changes should be more than enough then if you haven’t tested them yet. I’ve found that you can change the behavior of the rear a ton by working in a just 1/2″ window.
    Tire pressure isn’t dependent on chassis, just tire. YLCs should be around 11-13psi cold usually.
    Your front width sounds fine. One large spacer is the factory baseline.
    #31637
    FREDDY SANDOVAL
    Matt, TJ, and Brian
    Thank you for your help, you’re right, we’ll just have to test while running the race. We have 3 heat races to adjust, and the main event is the most important one.
    I will definitely tell my son about keeping his arms straight and steer with minimal effort and with more gentleness.
    Thank you all.
    #34889
    Rod Hawkins
    I assume you mean rear was 54 and now it is 55? That alone with do a lot.
    #34976
    FREDDY SANDOVAL
    Yeah, Rod
    And all of you guys for the input
    We brought the rear track back to 54, then narrowed the front track by one spacer
    played with tire pressure and now drives like a dream
    Thank you all, very much. Fast Freddy.
    The only issue I have now is that my boy from time to time keeps forgetting, and drives it like his 2011 Top Kart ( old kart )
    Doesn’t happen too much, just a couple of times now and then he shows that old behavior. Lol
    #34995
    Ted Hamilton
    Don’t forget seat positioning and effect on Vcg either… Us American drivers are slightly different build and size than the Euros they pattern those seats and dimensions after at the factories… 🙂
